Operation with a Nikon D300
Posted: 28 Jan 2017, 14:01
by giorgio150
I tried to connect the dslrdashboard software to a Nikon D300.
For this I used a USB cable. Unfortunately, clicking on the USB icon will not connect to the software.
Shortly then the software crashes.
What am I doing wrong? Looking forward to feedback ...
Greetings Jürgen
Re: Operation with a Nikon D300
Posted: 28 Jan 2017, 16:58
On what platform did you try (Android, Windows, OSX, Linux) ?
Posted: 28 Jan 2017, 17:15
by giorgio150
hubaiz wrote:On what platform did you try (Android, Windows, OSX, Linux) ?
I have a Macbook Pro with El Capitan 10.11.6
Posted: 28 Jan 2017, 17:56
Posted: 28 Jan 2017, 19:10
by giorgio150
hubaiz wrote:Try this OSX debug version: https://drive.google.com/file/d/0BxMZ8X ... sp=sharing
Thanks, but unfortunately the same problem. The camera is apparently not recognized. Can it be the settings of the camera?
We are currently working with Capture One 10. With this program the camera is recognized perfectly.
DSLRDashBoard would be much better for us, because you can work with this program also with an iPad...
Posted: 28 Jan 2017, 20:01
Is the camera set to PTP mode?
Be sure that no other application is using the camera as qDD will not be able to access it.
Note that on iOS USB connection is not possible.
edit: would work with the MR3040 solution using OpenWrt and ddserver
