No image review, no live view picture
matin
Post by matin »
Dear Zoltan,
I tested the previews of V3.5.2 and V3.5.3. There is no image review (surprisingly i see the thumbnails) and no live view picture available. Capturing is working although. All previous versions worked fine.
I use a 600d and 80d (both USB connected) on Win7-64 (Intel HD 3000).
Re: No image review, no live view picture
Did you test this V3.5.3 (this is a debug build): https://drive.google.com/file/d/0BxMZ8X ... sp=sharing
If yes did you use all the libraries from the archive? Probably you will need to run the vcredist_x64 again.
Here is also a release build: https://drive.google.com/file/d/0BxMZ8X ... sp=sharing
just unpack the qDslrDashboard.exe and overwrite the debug one.
matin
Post by matin »
Sorry, it's not working. Tried the entire debug build. Run vcredist_x64. And used the new exe.
Can you try to open one image in gallery and send me the log file (qdd_<date_time>.log in your Documents folder)?
Do you open JPG or RAW file?
matin
Post by matin »
I open both raw and jpg.
Strange that qdsrl did create a log file when i did your instructions. I got log files from yesterday testing only. So i sent you this. Hope this works for you..
qdd_logs.zip
(56.89 KiB) Downloaded 511 times
Please try this release build: https://drive.google.com/file/d/0BxMZ8X ... sp=sharing
(just unpack and overwrite the qDslrDashboard.exe )
What graphics card do you have?
matin
Post by matin »
Great. Its working now. Thanks a lot for the support. Btw: I use a Intel HD 3000
Arma
Post by Arma »
Hi Zoltan,
I also tested it.
I see that it makes dslrdashboard perfectly working in Angle mode!
So I'm no more obliged to set software mode with my old laptop Intel 965 video card. 8-)
But I also noticed that 3.5.3 with updated exe doesn't work in software mode.
3.5.3 without the latest exe update worked fine in software mode: I think it's worth keeping also software mode working...
Thank you!
Armando
Please check this build: https://drive.google.com/file/d/0BxMZ8X ... sp=sharing
Hope it will solve.
Arma
Post by Arma »
Just checked: it seems solved! 8-)
Armando
