Using in Netwerk
jan
Using in Netwerk
Post by jan »
Which setting do i need, if i want it use in my Network at home?
dhcp fixed ip???
Re: Using in Netwerk
There is no need.
But fixed IP is better since you know the address and do not need to check it every time.
jan
Post by jan »
Still problems.
If i use a network with 192.168.2.1 which ip i give the TP Link? I changed to dhcp client, qdslr software did not find the cam. with static ip 192.168.2.2 the software also did not find it.
jan wrote:Still problems.
Can you explain how your network is connect? How did you connect the TP-Link to your network? What IP has your home network and what IP has the TP-Link?
