Duplicate Shutter Speeds in Brackets
ClarusStudiosInc
Re: Duplicate Shutter Speeds in Brackets
Post by ClarusStudiosInc »
I'll have to test with the new update, but for me it was with slow shutter speeds starting from around 1/10th and going anywhere between 6-8 sec and 1/125th. Of course it was the over exposed shots that do it.
Shooting with a D3s and D600 and both have NR off.
Will download the new iOS app to see if it changes anything.
bobjones
Post by bobjones »
Any news on this?
carpemoment
Post by carpemoment »
I had the same problem occur. The next to the last bracket was a duplicate, last bracket was missing. I reset the order of the brackets and I haven't had the problem again since then.
What order was you using when you had the duplicate? Maybe the settings you used?
bobjones
Post by bobjones »
I'm still having this problem.
A7Rii iPad 4.
It was fine for a 12 hour shoot yesterday.
Then 4 hours into day 2 it duplicates random brackets. I cannot get it to create a correct bracket after it starts.
I've tried pulling the battery out, restarting both the app, ipad and camera... Once it starts doing it I'm screwed.
Luckily I have a patient client today... I wasted quite a bit of time trying different things to get this to work.
I am desperate for a fix for this. Is there ANYTHING I can do to help you debug and fix this?
It is a deal breaking major issue for me!
Please let me know!!!
bobjones
Post by bobjones »
Update: Brackets were broken for the rest of my shoot. Random brackets have doubled shutter speeds.
I cant use this professionally if brackets are going to randomly break in the middle of a shoot.
I'm desperate for help on this...
bobjones
Post by bobjones »
Update: day 4 and brackets work again... for now. But I have to check the exif shutter speeds each time I bracket now.
Is there a way to clear the app cache or something so I can at least try to fix this when it starts happening?
bobjones
Post by bobjones »
Update: Day 5 of the shoot it worked once and then doubled up the last bracket the second time I tried it.
I'm using a wireless trigger to shoot exposures with the live view and image review from dslrdashboard.
I then get safety brackets after I'm done shooting. Is it possible the wireless trigger is doing something?
Hubaiz... Can you please try to help me with this?
bobjones
Post by bobjones »
Bought a new iPad Pro 12.9 w/256GB of memory.
Still happens. Starts out working fine then random duplicate shutters.
I'd really appreciate some support on this Hubiaz (or a simple comment on this post to show you're not ignoring me).
Please let me know if there is ANY information I can give you to help get this resolved. It's a major issue for me.
Currently I don't have the a6300 so can't do any Sony related testing. Should get it back till end of month.
Edit: After this duplicate bracketing sequence happens can you change the shutter speed with the bottom shutter button in qDslrDashboard?
