Record Live View
Posted: 19 Apr 2017, 13:19
by mawes
app version is 3.5.3. I am running the D5300 ad-hoc wifi and a Sony Xperia Z4 tablet. The qDslrdashboard manual says: "Record live view while movie recording – if enabled, the application will save the live view stream into a local file when movie recording is started." I take that as the LV feed is saved on the cameras memory card. When I try to start recording from the tablet, the wifi disconnects. No recording is stored.
Re: Record Live View
Posted: 25 Apr 2017, 05:18
This feature is currently no implemented as it wasn't working properly.
Posted: 28 Apr 2017, 14:45
by GonzoG
Also - if you read camera manual you will see that there is no movie recording with built-in wifi on D5300
Posted: 18 May 2017, 11:14
by mawes
OK! I missed that! The D5300 manual actually says that you can end a wifi session in a number of ways, e.g. by starting a film recording.
