I posted a while ago about being able to get the app to work, it just doesn't review after capture and no photos are being stored on the device.
Everything else works as it should.
I've been using the app for years on my 5DMIII
If you have this working on your 5DMIV please let me know what camera setting you are using.
I just received my 2nd 5DMIV body, a replacement. I sent to first one back because I thought it was a problem with the camera.
I tested both wireless with the built-in 5d wifi and with the tp router I've been using on my MIII.
I tested on my Android tab that I've been using with the app since it came out.
And I tested on an IPad.
All with the same results.
It has to be a setting on the body that I am missing, even though I match my new MIV with the setting on my MIII.
5DMIV has anyone have this working?? Please Help
Re: 5DMIV has anyone have this working?? Please Help
I have the same problem. Works great with my 5d MII but the MIV won't save images to the device. I've tried everything I could think of to get it to work with no luck.
I have 3.5.3 on my ipad and connect to 5D4 using the camera's WIFI "smartphone connect"
for time lapse and auto holy grail Camera is set to "M", raw+jpg, works fine,.
David10321
Thanks for the reply.
Just to clarify.
Image review works ok?
You see the photos on your ipad after capture?
I have all the same settings, same device, same version but no image review.
I did send Zoltan a debug log so hopefully we will get this resolved.
Just to clarify.
David10321
Well Zoltan got it working for me.
If you are having problems I suggest contacting him.
It's a great app.
I use it everyday in my Real Estate Photography and become so dependent on it.
I want to thank Zoltan for the Great Customer Support.
It's a great app.
sorry, I was off for a few days. Do you mind sharing how Zoltan was able to help you ? I might run into the same problem yet.
thanks
thanks
David10321
He sent me a debug version.
I ran it.
Sent him the log file.
He than sent me another debug version and it was all working...
I ran it.
