due to NEF-Format changes which came with my new Z7ii i nedded to upgrade from 10.15.7 to Seqoia 15.4.
Had qdslrDashBoard 3.6.7 running on my MacBookPro. Meanwhile i updated to 3.6.12.
I can select the WiFi of the Cameras in the WifI-Selector of the Os and it shows that is connected.
If I want to connect to the camera within  qdslrDashBoard-App it says:
Failed to connect with wireless.
Try to disable your mobile data and try again.
Controlling  the camera via USB seems zo work so far.
Any idea?
When starting qdslrDashBoard-app on 10.15 there is a Message about incoming  connections to allow with 15 there is no message....
Cheers
Fritz
