by using a canon 1100d and the lrtimelaps mode conected with USB stops after a while. For the first it works, then the lrtimelaps screen closes and the capture stops. It's the same using an external timer.
Tested with Raw+jpeg every 6sec and 25sec.
Thanks,
fanne
lrtimelaps stops with USB on canon 1100d
Re: lrtimelaps stops with USB on canon 1100d
Please try this test version: https://drive.google.com/file/d/0BxMZ8X ... sp=sharing
Hi again,
I tested the special version today, but the bug already exists.
Config: lrtimelaps holygrail, lrtimelaps timer 6sec and 20sec (error at both setups), 1100d, Lenovo A7 40,...
Cheers,
fanne
Cheers,
fanne
Just ran into this same problem last night
* Camera triggered from slider, qDslr first runs fine, then stops and freezes the entire camera
* Camera showing a "busy" alert in the display
* qDslr becomes unresponsive
* Canon 6D with qDslr v.2.7
Same thing happened with a regular intervalometer instead of having the slider trigger the camera.
Using the intervalometer of qDslr didn't work either. qDslr eventually stopped and I had to reboot a few times.
Let me know if there are any special steps you want me to repeat for testing.
Kai
Kai
What where the settings (interval, shutter speed, slowest shutter speed) ?
my shutter speed range was from 1/200 to 1/50, interval 6sec and 20sec... And my cam wasn't freezing. Only the capturing stops and the lrtimelaps window was closed. The last time I tested it the lrtimlaps and the hole camera window was closed. So the app shows the startup window. May be the usb connection was interupted for a moment? But I didn't touched the cam or the wire or the tablet! And for the first 100 pics it works. I will try it with usb connection at the 70d next days. Let's see what happen...
cheers,
Fanne
cheers,
Fanne
Ok, and you used USB connection on Android with OTG adapter?
Yes... Please see the post before again. I edit it...
Just needed to be sure, will try to run a similar test tomorrow or on Sunday using the 650D and USB with Nexus7
The last hours I checked the usb connection. The cam was connected with the tablet and the app with lrtimelaps screen was activated. I only captured a reference pic. After 4 hours the app was working and the lrtimelaps screen was already shown. The connection seems to be okay!
