D5600
wox
D5600
Post by wox »
I didn`t find how to connect qdslrdashboard from Android to my Nikon D5600. I can only connect with snapbridge but not with qdslrdashboard. Can anyone give me a step by step tutorial please.
dslr
Re: D5600
Post by dslr »
same questions as the thread below because it's all about snapbridge...
(will probably continue future discussions using the thread below)
viewtopic.php?f=6&t=2261&p=6195&hilit=d500#p6195
have you successfully used snapbridge to start wifi on the d5600 and connected your android to its network...
(i don't have a d5600 but i'm guessing the default SSID name follows the same format as the d500, ie D5600_XXXXXXX, where XXXXXXX is the 7-digit camera serial number)
if so, then you just use the standard nikon wireless connection button (to connect to 192.168.1.1)
qdd documentations
https://dslrdashboard.info/documentation/
connection buttons (a touch outdated)
https://dslrdashboard.info/connection-screen-buttons/
JuandaTellez
Re: D5600
Post by JuandaTellez »
Hola acá dejo un video con las solución
https://www.youtube.com/watch?v=RHBJzYrOAKk&t=14s
