Dither with PHD Guiding
Posted: 29 Apr 2015, 12:49
Hi!
I'm new on the forum but i use this awesome app since early versions...
I used to control my D300 and now my D610, from pc and from my tablet on the field.
Now, i often shoot astrophotography, with my modded canon 450d, but from time to time i like to use the D610 to get better dynamic range on fainter galaxys.
With this application i can set the bulb intervalometer, but i miss the dither from the guiding program. I use PHD (as lots of people do) and it provides a server running on the pc to interact with other programs, and recieve command to "dither".
Dithering is awesome since it moves the frame for few pixels, so the target is not on the same part of the image and hot pixels and different pixel sensitivity is usually negated by stacking lots of subframe.
Is possible to implement this function (send the dither command between a shot and another while using the intervalometer)?
This could be useful only on the pc version of the software, since phd only runs on pc and not on mobile devices.
Thanks for any reply!
