TP-Link TL-MR3040 Firmware mods vs original
Posted: 01 May 2015, 18:42
by xma1e
Hi
Sorry if this has already been asked. What is the difference between the modified firmware for the TP-Link TL-MR3040 and the official OEM one?
Is there anything preventing me from using a different wireless router?
The reason I ask, is because there will come a time when it will be impossible to buy a TP-Link TL-MR3040.
Re: TP-Link TL-MR3040 Firmware mods vs original
Posted: 01 May 2015, 18:54
The original TP-Link firmware can't be modified.
The OpenWrt (
https://openwrt.org ) is described as a Linux distribution for embedded devices.
It can be extended, in this case with the small application called ddserver (DslrDashboardServer -
https://github.com/hubaiz/DslrDashboardServer ) that acts as a proxy server for PTP packets.
Posted: 01 May 2015, 19:42
by xma1e
Thanks.
Is this the same as used in DSLR Controller (Android)?
Posted: 01 May 2015, 20:17
No it is not. ddserver is opensource the DslrController solution is not.
Posted: 24 May 2015, 22:54
by xma1e
Is it possible to reset a MR3040 back to it's original firmware?
I am considering using the smaller HAME MPR-A2 router so will want to re-allocate the TP router for something else.
Posted: 25 May 2015, 05:02
It is but not so light, here it is described:
http://wiki.openwrt.org/toh/tp-link/tl-mr3040
Scroll down to 'Restoring original firmware'
The Hame A2 is not so smaller then the MR3040.
It has same length as the MR3040, it is thicker and a narrower then the MR3040.
Posted: 25 May 2015, 09:20
by xma1e
Thanks. My main concern is the rising price of the MR3040 in my area as the product becomes harder to source. I can buy the Hame A2 for half the price, so will get two, one for use and one as an emergency backup.
Posted: 25 May 2015, 20:05
by xma1e
Is there anywhere the process is documented in a step by step form?
On Openwrt it is not very clear at all.
Posted: 27 May 2015, 07:31
It is the only explanation I found and as I wrote it is not so easy.
