qDSLRdashboard not saving pics on camera memory?
Posted: 19 Sep 2017, 15:22
by jasperv21
Hello everyone,
I'm quite new to qDLSR dashboard, so this might be a stupid question.
I use qDSLR dashboard when I'm photographing hundreds of plants for my experiments (I'm a PhD in plant science).
I'm using a Nikon D3200, which I connect to my macbook pro through a USB cable. Apparently, when I'm taking pictures using qDSLR dashboard,
the program sometimes saves the pictures to my macbook, without me noticing. These pictures are then not saved on the SD card of my camera.
Is there any way to switch this off or control this? I looked through the program, but could not really find how to do this.
Thanks!
Cheers,
Jasper
Re: qDSLRdashboard not saving pics on camera memory?
Posted: 19 Sep 2017, 19:21
You can switch between the capture destination by long pressing the qDslrDashboard 'capture' button.
If the capture button is red it means the images will be downloaded to the controlling device.
If the capture button is white it means the images will be saved to the camera SD card.
