Setting up qDslrdashboard and NMX Controller
Posted: 27 Oct 2017, 17:55
Hi guy's,
I've just taken delivery of the NMX controller to upgrade my Dynamic Perception Stage One slider from the MX2 controller. I thought I would find lots of info on using this combination together but having tried to search on the term "NMX" I get a message saying it is too common a word and no results show up. If I search via google I get references to two posts dated back in 2015 but can't find further info. So can I ask for some help please.
First off, does qDslrboard talk to the NMX controller? Either via bluetooth or another mean's? If so, what do I do to get it working?
If it doesn't physically (or via bluetooth) link up together, I presume it works the same way as before i.e. qDslr controls the camera (Sony A7Rii via the remote App) and the NMX looks after the motion and timing of the hardware. If this is the case, can I sync the timing up? Again I presume there is no camera trigger cable from the NMX to the camera when I'm using Qdslr or is there both the cable attached to the camera from the NMX and I use the remote App at the same time?
Can't wait to get this up and running, I hope someone can spare a moment and let me know the correct way to setup the kit.
Thanks.
Thanks.
