Mini OpenWRT Router
Re: Mini OpenWRT Router
You should have those packages available where you downloaded the OpenWrt image for the VCore2
If it is connected to internet you can install it with opkg or using the Luci web interface
fotokiste
Post by fotokiste »
Many Thanks,
I have seen about Luci - system - software that ddserver (0.2-14) is installed and started.
Now I have USB USB (white) and USB DP (green) and GND (black) a USB cable for the camera connected.
Then my tablet connected to the VoCore WIFI, Qdslrdashboard started, but unfortunately no camera connection is made.
Do I still have to configure something with the USB connection?
fotokiste
Post by fotokiste »
can the camera USB connection on VoCore see / test?
Check this post regarding the ddserver installation: viewtopic.php?f=5&t=2101
fotokiste
Post by fotokiste »
i think i have a problem with the ddserver package.
if i want install the package, i comes an error = Cannot satisfy the following dependencies for ddserver: uclibcxx
so i use opkg install --force-depends .... , so the ddserver0.14 ist installed and runs,
but this error comes: Cannot satisfy the following dependencies for ddserver: uclibcxx
in the system-logs no USB connect messages, only this messages:
kern.err.kernel: mtk-sd 10130000.sdhci no support for card's volts
mmc0: error -22 whilst initialising MMC card
i have install the last .bin from VoCore Site
fotokiste
Post by fotokiste »
Would it be a good way
connect the VoCore with USB, enable AP + STA mode,
so that I come to the Internet with the VoCore and
then do the updates?
Could I then install the internet the DDServer?
fotokiste
Post by fotokiste »
I am still big steps ahead!
Have the following packages installed manually:
libpthread_0.9.33.2-1_ramips_24kec.ipk
librt_0.9.33.2-1_ramips_24kec.ipk
libusb-1.0_1.0.19-1_ramips_24kec.ipk
uclibcxx_0.2.4-1_ramips_24kec.ipk
usbutils_007-1_ramips_24kec.ipk
zlib_1.2.8-1_ramips_24kec.ipk
After that I was able to install this package:
ddserver_0.2-14_ramips_24kec.ipk
Have the camera (Nikon D800) s.ein HUB and the VoCore2 also to this hub (GND, D +, D-, VCC).
But in the console I only see at lsusb:
Bus 002 Device 001: ID 1d6b: 0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b: 0002 Linux Foundation 2.1 root hub
When I try to connect to qDSLR:
Searching DDServer
DDServer not found, connecting to IP: 192.168.1.1
List connected DSLR at IP: 192.168.1.1
Error getting DSLR list from IP: 192.168.1.1
In the syslog of VoCore:
USB device in
Number of possible configuration 1 Device Class: 9 VendorID: 7531, ProductID: 1
Number of alternate settings:
Interface class: 9 Interface number: 0 Number of endpoints: 1
Number of possible configuration 1 Device Class: 9 VendorID: 7531, ProductID: 2
Imaging USB devices found: 0
Error reading total packet size: 0
Stopping client
Closing USB device
Can everyone help me?
fotokiste
Post by fotokiste »
latest Status:
in Putty, with lsusb i see the Nikon D800 (ptp) - fine
root@OpenWrt:~# lsusb
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 003: ID 04b0:042a Nikon Corp. D800 (ptp)
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@OpenWrt:~# lsusb -v -d 04b0:042a
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.10
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x04b0 Nikon Corp.
idProduct 0x042a D800 (ptp)
bcdDevice 1.00
iManufacturer 1 NIKON
iProduct 2 NIKON DSC D800
iSerial 3 000006115021
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 39
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 2mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 6 Imaging
bInterfaceSubClass 1 Still Image Capture
bInterfaceProtocol 1 Picture Transfer Protocol (PIMA 15470)
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 9
Binary Object Store Descriptor:
bLength 5
bDescriptorType 15
wTotalLength 22
bNumDeviceCaps 2
USB 2.0 Extension Device Capability:
bLength 7
bDescriptorType 16
bDevCapabilityType 2
bmAttributes 0x00000002
Link Power Management (LPM) Supported
SuperSpeed USB Device Capability:
bLength 10
bDescriptorType 16
bDevCapabilityType 3
bmAttributes 0x00
wSpeedsSupported 0x000e
Device can operate at Full Speed (12Mbps)
Device can operate at High Speed (480Mbps)
Device can operate at SuperSpeed (5Gbps)
bFunctionalitySupport 1
Lowest fully-functional device speed is Full Speed (12Mbps)
bU1DevExitLat 1 micro seconds
bU2DevExitLat 101 micro seconds
Device Status: 0x0001
Self Powered
But in System Log:
Sat Feb 3 08:38:23 2018 kern.info kernel: [ 77.380000] usb 1-1: new high-speed USB device number 2 using ehci-platform
Sat Feb 3 08:38:24 2018 kern.info kernel: [ 78.200000] usb 1-1: new high-speed USB device number 3 using ehci-platform
Sat Feb 3 08:38:24 2018 kern.debug kernel: [ 78.350000] usb 1-1: no of_node; not parsing pinctrl DT
-->no connection with ddserver
anyone an idea ?
please help me ... thanks
Bluesmell
Post by Bluesmell »
Have you had any luck with Vocore2 ?
I have different problem. Want to connect camera via Wifi and control it over (wired) LAN.
Has anybody tried that approach? Also maybe DDServer can be modded to connect to camera via Wifi instead USB?
Any info will be helpful.
Thanks.
