How to install DD server?
Posted: 08 Jan 2018, 12:22
I have Raspberry Pi 3b and Ubuntu Mate. I tried to install DD server as follows:
....but the following text appeared::
Could anyone help such a beginner with this? What I have to do?
sudo apt-get install build-essential pkg-config libusb-1.0-0-dev
g++ -Wall src/main.cpp src/communicator.cpp `pkg-config --libs --cflags libusb-1.0` -lpthread -lrt -lstdc++ -o ddserverCode: Select all
Reading package lists... Done
Building dependency tree
Reading state information... Done
build-essential is already the newest version (12.1ubuntu2).
libusb-1.0-0-dev is already the newest version (2:1.0.20-1).
libusb-1.0-0-dev set to manually installed.
pkg-config is already the newest version (0.29.1-0ubuntu1).
0 upgraded, 0 newly installed, 0 to remove and 53 not upgraded.
