Audio question when using video
Posted: 23 Feb 2018, 15:12
by adinis78
I have a D7200 and running qdslrdashboard on both an ipad and a samsung tablet. The iapd has version 3.5.5 and the samsung has version 3.5.3. Now everything works fine aside from the audio when palying back video and its only on the Samsung tablet. On the ipad i have no issues. Any suggestions. Thanks.
Re: Audio question when using video
Posted: 02 Mar 2018, 23:17
by GonzoG
With that you have to go to Samsung. It's problem with codecs in installed system.
Posted: 05 Mar 2018, 13:09
by adinis78
GonzoG wrote: ↑02 Mar 2018, 23:17 With that you have to go to Samsung. It's problem with codecs in installed system.
Thank you. Its a shame as i would like to use it instead of my ipad. Guess will only be used as a pic viewer. Any ideas as to what codecs are needed?
Posted: 05 Mar 2018, 13:24
by adinis78
Ok just solved my issue. I downloaded VLC for android and i get audio.
