Questions for RPi instalation
Posted: 25 Mar 2018, 18:23
by IkaSGC
Hello, in new here and have many questions for dslrDashboard.
First, I found an error in the manual:
"download the qDslrDashboard V3.5.5 Stretch image and unpack:
tar -xzvf ~/Downloads/qDslrDashboard_V3.5.5_RPI_Stretch.tar.gz"
I'm not a Linux expert, but with the tar command, I probably will not download it. It's a confusion for amateurs, like me.
After I downloaded and executed the rest of the manual, I continue running:
"pi@DSLR-Pi:~/qDslrDashboard_V3.5.5_RPI_Stretch $ Unable to query physical screen size, defaulting to 100 dpi.
qt.qpa.input: X-less xkbcommon not available, not performing key mapping
qt.bluetooth.bluez: Missing CAP_NET_ADMIN permission. Cannot determine whether a found address is of random or public type.
qml: windowRoot completed
qml: manager focus
qml: managerOverlayLoader active focus changed true
qml: manager overlay got focus true
qml: button active focus changed true index 0
qml: displayScreen DeviceScreen.qml
qml: on device buttons changed null
qml: getTime 0
qml: screenModel DeviceScreen(0x2478990) devBtn null
qml: get osd source qml
qml: getTime 0
qml: DeviceScreen completed
qml: ScreenBase completed DeviceScreen(0x2478990)
qml: error:
glGetError 0x500
qml: Timer triggered"
That is end, what now? How to connect to dashboard ?
It is clear that I have to connect Nikon (in my case 5100) via USB. But how do I connect Android Tablet for example? So I can control the nikon?
Please advise, I need to check Nikon for the NexStar SLT telescope.
Re: Questions for RPi instalation
Posted: 26 Mar 2018, 09:07
You connect your DSLR with USB to your Raspberry Pi and controll with it.
Running qDslrDashboard on Raspberry Pi means that it is connected to a screen and use it to controll you DSLR.
To control with Android you will need qDslrDashboard on it and you need to connect your DSLR with the Android device either with USB or wireless.
