TP-Link TL-WR902AC AC750 v.3
nirmitpatel
Re: TP-Link TL-WR902AC AC750 v.3
Post by nirmitpatel » 03 Apr 2019, 08:56
cobra98 wrote:
30 Jan 2019, 13:44
Hi, i installed the v3 version by https://openwrt.org/toh/hwdata/tp-link/ ... wr902ac_v3 but in your manual i miss how to get dslr dashboard server on it after.
I looked at https://github.com/hubaiz/DslrDashboardServer but have no clue how to compile it on the router with openwrt installed.
Maybe i missed something in your manual.
So far it described that dslr dashboard runs on it and in the description you describe only the installation of the firmware which can be done by tftp
instructions i found here https://git.openwrt.org/?p=openwrt/open ... 6530025098
Thanks for your valuable reply.Here I got my solution.Helpful :) well done.....
bswan
Post by bswan » 12 Jun 2019, 19:49
Has anyone who has tried this router compared real world speeds with any of the N routers? Thinking of upgrading my GL iNet 300M to this one if it provides faster transfer of photos
wlayher
Post by wlayher » 14 Jun 2019, 08:40
If I connect my tablet to the 2.4 GHz network of this router, the status page shows a resting bitrate (no active transfers) of around 115-130 Mbit/s with 20 MHz channel bandwidth. If I connect to the 5 GHz network, these values are around 300 Mbit/s and 80 MHz channel bandwidth. I expect these bitrate values to be even higher during an active transfer.
From experience using it to display the last capture on a 5DMk3, the display of a RAW takes around 1 s, display of a jpg is almost immediately (on 5 GHz). I don't use wifi to transfer all images on a card to my laptop, so I can't offer any throughput values for that.
bswan
Post by bswan » 14 Jun 2019, 18:33
Excellent, thanks for the info. That sounds like it's probably enough to be an upgrade for me
Who is online
Users browsing this forum: No registered users and 3 guests
