Crash with Sony A7lll
hajo
Post by hajo »
bought the latest Samsung Galaxy Tab A 2018 and trying to use it with my fresh bought copy of qdslrdashboard.
I can connect my Sony A7lll to the app and it recognize my Camera but then it crashes.
No way to use it.
With my a6000 it is working fine.
Is there a way to find the problem? Log files?
I am new to android, long term iPad and iPhone user.
Kind regards
blackice2999
Re: Crash with Sony A7lll
Post by blackice2999 »
Worked it on the first time of you start?
I had a similar problem with a Sony A7RIII and hubaiz is already debugging it.
Yes, I'm trying to figure out the problem, unfortunately I can't reproduce it with the a6300, seams it is only a a7m3 and a7r3 problem.
Joseph Kwok
Post by Joseph Kwok »
I also use Sony A7iii and experienced the same problem.
The app (iOS) can be used after download from App Store. But the app crash when I tried to connect A7iii at the second time. Then I need to remove the app and install it again to make it work only once. So I need to repeat this process until the bug fix.
Hope it can be solved shortly. Thanks!
hajo
Post by hajo »
Sorry for my late reply.
Anyway, I got it solved by a youtube video.
In settings - apps - qdslrdashboard: i deleted data and cache and it is now working with my sony a7lll.
Kind regards
Joseph Kwok
Hi hajo,
Do you mean “clear local thumbs” to delete data and cache for iPhone app?
Joseph Kwok wrote: ↑09 Jan 2019, 23:46 Hi hajo,
He was referring to an Android device.
blackice2999
Hi Hubaiz,
this issue sounds exactly like the issue i reported to you over email in 12.2018.
You solved it for me by providing a debug version with a longer wait time after connect. See my mails from 08.02.2019 and 28.12.2019
It now works fine, but i need to work with debug version. I think this user here has the same problem with the timing.
regards
Dennis
blackice2999 wrote: ↑28 Feb 2019, 08:06 Hi Hubaiz,
regards
Dennis
That was my thought to, I'm still working on a new version, hope soon I can release it.
hensil
Post by hensil »
My friend has Sony a9 and a7r3 and he also had the same problem with both the cameras. the QDD would work for couple of time but after that it will continuously crash till the QDD is reinstalled. Then the same would happen.
As the Op suggested I asked him to clear the QDD data and cache in his android tab, that FIXED the problem.
Henry
