is there a changelog for the lastest version so we know what we
should pay attention to when testing ?
Changelog V0.2.7_16 test version for Android ?
Re: Changelog V0.2.7_16 test version for Android ?
Sorry missed the post.
Mostly bugfixes.
Hope over weekend I will be able to build and publish the V0.2.8
Mostly bugfixes.
Will 0.2.8 have any real fixes over 0.2.7_16? There are some significant performance issues with qDD on the m7 (I know I keep banging on about this but it's the device I have so...)
Please check this test version: https://drive.google.com/file/d/0BxMZ8X ... sp=sharing
And this one (this is the latest) https://drive.google.com/file/d/0BxMZ8X ... sp=sharing
Neither is any better. Is there a way to enable logging (or maybe even a special build with it enabled)? I'd be more than happy to provide logs if it's going to be helpful.
Not sure if the log could help with this but here is a debug build: https://drive.google.com/file/d/0BxMZ8X ... sp=sharing
It will generate a qdd_<date_time>.log file in your Documents folder.
I think the problem is with OpenGL but not sure why.
Hello everybody, I'm new here and I'm recently following this app.
Watching YouTube reviwes is a great app, but having an Asus memo pad HD 7 I founded difficult almost everything
If it helps I pest below my log file... sorry for my English
09:07:19:824 Debug: DslrScreenManager constructor, platform: 5
09:07:19:826 Debug: Init settings
09:07:19:832 Debug: "/storage/emulated/0/DCIM/DslrDashboardThumbs" local "/storage/emulated/0/DCIM/DslrDashboardThumbs/localthumbs" sdcard "/storage/emulated/0/DCIM/DslrDashboardThumbs/sdcardthumbs"
09:07:19:833 Debug: Init settings rest
09:07:19:834 Debug: DPI: 95.85
09:07:19:834 Debug: pdpi: 212.467
09:07:19:835 Debug: asw: 0 ash: 0
09:07:19:836 Debug: agw: 0 agh: 0
09:07:19:837 Debug: gw: 1280 gh: 736
09:07:19:837 Debug: pw: 153 ph: 88
09:07:19:838 Debug: sw: 1280 h: 736
09:07:19:839 Debug: scaledDensity: 1.33125
09:07:19:840 Debug: width: 1280
09:07:19:840 Debug: height: 736
09:07:19:841 Debug: density: 1.33125
09:07:19:842 Debug: xdpi: 213
09:07:19:842 Debug: ydpi: 213
09:07:19:843 Debug: densityDpi: 213
09:07:19:844 Debug: Android sFactor: 1.33125
09:07:19:845 Debug: Calculated scale factor: 1.33125
09:07:19:845 Debug: ScaleFactor: 1.33125
09:07:19:980 Debug: XML parsed
09:07:20:069 Debug: ThreadWorker::ThreadWorker "thumb loader worker"
09:07:20:072 Debug: ThreadWorker::execute enter "thumb loader worker"
09:07:20:072 Debug: DslrScreenManager::moveToScreen 0
09:07:20:076 Debug: usb hotplug callback registered
09:07:20:076 Debug: ThreadWorker::ThreadWorker "usb hotplug worker"
09:07:20:077 Debug: ThreadWorker::execute enter "usb hotplug worker"
09:07:20:079 Debug: UDP interface: ""
09:07:20:080 Debug: server listening on: QHostAddress(QHostAddress::Any) port: 4757
09:07:20:101 Debug: DslrSettings::ensurePath "/storage/emulated/0/DCIM/DslrDashboard"
09:07:20:110 Debug: DslrGpsHelper::DslrGpsHelper PositionInfoSource found
09:07:20:110 Debug: Min update interval: 1000
09:07:20:113 Debug: NumSamples: 4096
09:07:20:114 Debug: SpectrumAnalyser::SpectrumAnalyser
09:07:20:134 Debug: Audio input devices:
09:07:20:135 Debug: "mic"
09:07:20:136 Debug: "camcorder"
09:07:20:137 Debug: "voicerecognition"
09:07:20:137 Debug: Default Audio name: "mic"
09:07:20:138 Debug: Supported byte order: (LittleEndian)
09:07:20:558 Debug: Supported channel count: (1, 2)
09:07:20:559 Debug: Supported codecs: ("audio/pcm")
09:07:20:560 Debug: Supported sample rate: (8000, 11025, 12000, 16000, 22050, 24000, 32000, 44100, 48000)
09:07:20:561 Debug: Supported sample size: (16)
09:07:20:561 Debug: Supported sample type: (SignedInt)
09:07:20:562 Debug: Format is supported
09:07:20:563 Debug: Order: LittleEndian codec: "audio/pcm" sSize: 16 type: SignedInt cCount: 1 rate: 44100
09:07:20:564 Debug: mSpectrumSize 8192
09:07:20:570 Debug: DslrScreenManager::moveToScreen 1
09:07:20:571 Debug: DslrScreenManager::doDisplayScreen 1
09:07:23:107 Debug: DslrScreenBase::DslrScreenBase
09:07:23:108 Debug: DslrConnectionScreen::DslrConnectionScreen
09:07:23:281 Debug: DslrUIBase::setScreenManager DslrScreenManager_QML_4(0x585cfcb8)
09:07:23:292 Debug: DslrSettings::ensurePath "/storage/emulated/0/DCIM/DslrDashboard"
09:07:25:119 Debug: DslrScreenBase::setScreenData QObject(0x0)
09:07:25:122 Debug: DslrScreenManager::moveToScreen exit
09:11:29:098 Warning: Can't find surface 1
09:11:56:366 Debug: usb device attached
09:11:56:366 Debug: Number of possible configurations: 1 Device Class: 9 VendorID: 1507 ProductID: 1544
09:11:56:367 Debug: Number of alternate settings: 1
09:11:56:368 Debug: Interface class: 9 Interface number: 0 Number of endpoints: 1
09:11:56:747 Debug: usb device attached
09:11:56:749 Debug: Number of possible configurations: 1 Device Class: 0 VendorID: 1193 ProductID: 12914
09:11:56:749 Debug: Number of alternate settings: 1
09:11:56:750 Debug: Interface class: 6 Interface number: 0 Number of endpoints: 3
09:11:56:750 Debug: Found USB imaging device, get vendor and product
09:11:56:751 Debug: Error opening USB imaging device: -3
09:12:07:487 Debug: DslrButtonManager::onButtonPressed 1
09:12:10:499 Debug: DslrButtonManager::onButtonPressed 1
09:12:11:732 Debug: DslrButtonManager::onButtonPressed 1
09:12:15:271 Debug: DslrButtonManager::onButtonPressed 1
09:12:29:891 Debug: DslrButtonManager::onButtonPressed 1
09:12:34:992 Debug: DslrButtonManager::onButtonPressed 1
09:12:36:788 Debug: DslrButtonManager::onButtonPressed 1
09:12:50:953 Debug: DslrButtonManager::onButtonPressed 1
09:12:54:946 Debug: DslrButtonManager::onButtonPressed 1
09:12:58:986 Debug: DslrButtonManager::onButtonPressed 1
09:13:12:541 Debug: DslrButtonManager::onButtonPressed 8
09:13:12:542 Debug: DslrScreenManager::applicationClosing
09:13:12:543 Debug: DslrScreenManager::doDisplayScreen 1
09:13:12:548 Debug: DslrScreenBase::beforeCloseScreen
09:13:12:554 Debug: DslrScreenBase::DslrScreenBase
09:13:12:555 Debug: DslrConnectionScreen::DslrConnectionScreen
09:13:12:687 Debug: DslrUIBase::setScreenManager DslrScreenManager_QML_4(0x585cfcb8)
09:13:12:695 Debug: DslrSettings::ensurePath "/storage/emulated/0/DCIM/DslrDashboard"
09:13:13:366 Debug: DslrScreenBase::setScreenData QObject(0x0)
09:13:13:420 Debug: Exiting application
09:13:13:430 Debug: DslrConnectionScreen::~DslrConnectionScreen
09:13:13:431 Debug: DslrScreenBase::~DslrScreenBase
09:13:13:432 Debug: DslrUIBase::~DslrUIBase
09:13:13:440 Debug: DslrButtonManager::~DslrButtonManager
09:13:13:740 Debug: DslrDeviceManager drop
09:13:13:742 Debug: delete local images
09:13:13:742 Debug: delete audio capture
09:13:13:743 Debug: delete ddserver discovery
09:13:13:744 Debug: delete usb hotplug helper
09:13:13:745 Debug: ThreadWorker::stop "usb hotplug worker"
09:13:13:746 Debug: ~UsbHotplugHelper
09:13:13:747 Debug: ThreadWorker::stop "usb hotplug worker"
09:13:13:748 Debug: close tcp server
09:13:13:748 Debug: close mSocket
09:13:13:750 Debug: DDServerDiscovery::~DDServerDiscovery
09:13:13:751 Debug: delete ssdp discovery
09:13:13:751 Debug: ~SsdpDiscover
09:13:13:752 Debug: delete devices list
09:13:13:753 Debug: delete devices
09:13:13:754 Debug: delete settings
09:13:13:754 Debug: DslrSettings drop
09:13:13:755 Debug: DslrSettings destructor
09:13:13:756 Debug: delete thumb loader
09:13:13:756 Debug: DslrThumbLoader drop
09:13:13:757 Debug: DslrThumbLoader::pause
09:13:13:758 Debug: DslrThumbLoader::~DslrThumbLoader
09:13:13:758 Debug: DslrThumbLoader::pause
09:13:13:759 Debug: DslrThumbLoader::pause
09:13:13:760 Debug: ThreadWorker::stop "thumb loader worker"
09:13:13:760 Debug: delete resource manager
09:13:13:761 Debug: DslrProfileManager drop
09:13:13:762 Debug: delete android helper
09:13:13:763 Debug: AndroidJniHelper::~AndroidJniHelper
09:13:13:764 Debug: DslrScreenManager destructor
09:13:13:768 Debug: ThreadWorker::execute exit "thumb loader worker"
09:13:13:769 Debug: ThreadWorker::~ThreadWorker "thumb loader worker"
09:13:13:848 Debug: ThreadWorker::execute exit "usb hotplug worker"
09:13:13:849 Debug: ThreadWorker::~ThreadWorker "usb hotplug worker"
09:13:14:095 Debug: DslrConnectionScreen::~DslrConnectionScreen
09:13:14:096 Debug: DslrScreenBase::~DslrScreenBase
09:13:14:097 Debug: DslrUIBase::~DslrUIBase
09:13:14:099 Debug: DslrButtonManager::~DslrButtonManager
Hi, i just installed New 0.2.8 version but is still not working
Please heeeeeelp
Please heeeeeelp
