I used to use qDSLRdashboard with my iPhone, haven't used it for a while. Went to run it today and it just exits after the splash screen. I restarted the phone, same problem. So I deleted the app and went looking on app store, but could not find. Came here to find it has been replace with controlmycamera. So I bought (£9.99) controlmycamera from the apple App Store, only to find it does the same thing. The smash screen loads with the product name and copyright but exits straight away.
wlayher wrote: ↑06 Dec 2018, 21:38
I had the same problem. I set the search filter in the App Store to "sort by release date" and there it was.
the problem is, when I delete the 3.5.6 Version on my iPhone and download it again, there is again the 3.5.6 version on my iPhone, no 3.5.7 no ControlMyCamera 1.0.0
Best regards
Ingo
Best regards
Ingo
You will not get ControlMyCamera if you purchased qDslrDashboard, it is a new application.
qDslrDashboard is updated to V3.5.7, maybe it needs some time to be updated in the iTunes store.
I double checked everything and the V3.5.7 update is active.
