Odroid-C1, EOS and qdslrdashboard
chlorisdroid
Post by chlorisdroid »
qdslrdashboard dd server software is running on the odroid-c1. So I made a litte video and posted it on
https://blog.georgmill.de/2015/05/15/od ... lr-camera/ with some instructions on how to do this.
Have fun.
Re: Odroid-C1, EOS and qdslrdashboard
Nice
I have an Odroid-U3, had no time yet to cross-compile Qt for it, hope will find time.
Also will see to get a C1 to
chlorisdroid
yes, do it. The Odroid-C1 is great. Community is good. But maybe dd server also runs on your U3? I don't own it, so I can't tell you if it works.
Thanks for your fascinating and very helpful software.
Is it possible to send commands to the dd server via bash commandline, a kind of headless communication?
Thanks.
Don't think, you must open a TCP connection to it, fetch the connect DSLR list and then establish a connection with the DSLR device.
It is only a proxy server that forwared PTP packets over network.
chlorisdroid
So I think it would be easier to do it with http://www.gphoto.org/proj/gphoto2/, which can be run from command line and can be easily used for scripting. So you can use qdslrDashboard for easy previewing and gphoto2 for fast production. It supports a lot of cameras http://www.gphoto.org/proj/libgphoto2/support.php
