manually add gps coordinate
inbremen
Post by inbremen »
i found that Itisavery difficultthing to locate my curent location on the map. so pls add manully input coordinate function. thx
wlayher
Re: manually add gps coordinate
Post by wlayher »
You can use a geotracking app on your mobile device to record a gps track and save/export it in gpx format. Later you can import the gps data into your images within Lightroom or with a Windows app called GeoSetter. This handles gps data for all your images, even those not taken using qDslrDashboard.
