Connecting to Nikion D3500
Posted: 22 May 2019, 02:51
by knight785
Hi, I just got D3500 and I was looking around to see if there is any way I can take time lapse on it for, then I came across qdslrdashboard, and I installed the windows app. However, when I went to connect my camera it didn't work. I tried w/ USB cable too but no luck. Any suggestion?
Re: Connecting to Nikion D3500
Posted: 22 May 2019, 05:55
Please try this newer build: http://bit.ly/2VFoz6m
Posted: 22 May 2019, 23:46
by knight785
Hey, so downloaded the newer version, but still, it's not working, can you please provide step by step process of connecting to a camera? I would appreciate that.
Posted: 23 May 2019, 06:38
Install the WinUSB driver by following the instructions here: https://dslrdashboard.info/windows-inst ... sb-driver/
Start qDslrDashboard
Connect your camera with USB to your PC
In qDslrDashboard press the 'USB' button (first from left).
Posted: 12 Apr 2020, 18:13
by t0rian
hubaiz wrote: ↑23 May 2019, 06:38 Install the WinUSB driver by following the instructions here: https://dslrdashboard.info/windows-inst ... sb-driver/
Thank you very much, just registered to say it worked very well =)
