Mirror Lock Up?
russellsnr
Mirror Lock Up?
Post by russellsnr »
Hi, Does QDSL allow you to set mirror lock up during stills photography on a Canon DSLR and if so how please, I have looked thruogh the index and searched here for mirror lock up but cannot find the answer. Thankyou. Russ.
Re: Mirror Lock Up?
Currently you must use the camera menu to enable/disable the mirror lockup mode (will fix for next version the property).
After you enabled the mirror lockup mode you can use the capture button that will raise the mirror and then you need to press the 'Capture' button in the dialog the execute the actual capture.
Or you can use the mirror delay button on left to add an 1, 2 or 3 sec delay.
russellsnr
Re: Mirror Lock Up?
Many thanks, looking forward to the next update. Russ.
