Nikon D7200 + WiFi
Posted: 17 Dec 2019, 09:20
by Pietrotre
I have a problem to connect D7200 with WiFi at the PC.
with MAc all works fine, with PC qDSLr doesn't see the D7200, and i can't find a solution. In USB mode it works
thanks
Re: Nikon D7200 + WiFi
Posted: 17 Dec 2019, 10:46
Is your PC also connected to your local network with wired network?
Check that there is no IP conflict, by default the Nikon cameras use the 192.168.1.1 IP address.
Posted: 17 Dec 2019, 17:50
by Pietrotre
yes, is connected with wire.
is there something to do?
Posted: 18 Dec 2019, 18:32
Try disconnecting your wired network and then connecting to the camera.
If that works you either need to change the camera IP or your local network IP (I guess changing the camera IP is easier)
Posted: 19 Dec 2019, 18:09
by Pietrotre
I tried, but still not connect the camera
Posted: 19 Dec 2019, 18:47
by Pietrotre
and now the camera is not seen from pc as SD reader...
