Using qDslrDashboard built-in intervalometer
Rachel Heseltine
Post by Rachel Heseltine »
I should like to use the ramping time option, but it’s greyed out. Why is this. I want to increase the interval with the decrease in shutter speed from 1000 to 10secs that is sunset to darkness. I don’t want to change the fstop. Please advise.
Thanks. RH
Re: Using qDslrDashboard built-in intervalometer
It will be enabled after you start the interval timer
