Canon EOS RP Live View
jonaskl
Post by jonaskl »
Hi there,
apparently I cannot disable the "LV" function in qDslrDashboard on Android/PC when it is connected to my Canon EOS RP. This means I cannot use any Intervalometer or any other external trigger.
Is there any workaround or fix for this?
Thanks a lot and stay healthy!
Re: Canon EOS RP Live View
Please try this newer Windows build: https://drive.google.com/file/d/1KCO_0j ... sp=sharing
Lennart
Post by Lennart »
Hi, I'm having the same issue (with the "default" R). The newer windows build just crashes once I click connect.
ErikaBr
Post by ErikaBr »
I have the same problem with Canon EOS M50 and M6 Mark II.
With the Canon EOS 60D it works fine.
I tried to install the new Windows build on my X86-laptop, but it will not run on my old Win 8.1 Pro:
"This Windows Version (6.3.9600) does not support the required Bluetooth API. Consider updating to a more recent Windoes (10.0.10586 or above)"
Thankyou for help,
Erika
