Compatible with Android
Posted: 09 Dec 2020, 14:14
by LordLiverpool
Hey
Can anyone please tell me if qDslrDashboard is compatible with my Android Tablet:
Make: Samsung
Model: Galaxy Tab 2 10.1
Android Version: 4.2.2 (Jelly Bean)
Released: Feb 11th 2013.
Model Number: GT-P5110
Kernel Version: 3.0.31-1238973 se.infra@SEP-70 #1 Tue Aug 13 20:09:49 KST 2013
Build Number: JDQ39.P5110XXDMH2
Thanks in advance.
Re: Compatible with Android
Posted: 09 Dec 2020, 19:27
Yes, 4.2.2 should work.
Posted: 09 Dec 2020, 19:47
by LordLiverpool
Again, thanks for replying.
It's great to know I can get my tablet and camera working using your app.
Thanks very much!
Posted: 10 Jan 2021, 10:43
by technet2
I was testing Samsung TAB2 10.1 (P5110) with Android 4.2.2 and it can't be started correctly. There was a problem with OTG. Maybe to solve if you change programming options for USB.
But after upgrade P5110 to SlimRom7 (Android 7.1.2) everything works great (Canon 60D, 500D). In addition, my tablet is not loaded with Samsung apps and works with new apps previously not available for it (e.g. for FIMI X8).
Posted: 12 Jan 2021, 09:48
by LordLiverpool
@technet2
How did you manage to upgrade from Android 4.2.2 to 7.1.2?
I couldn't find any decent enough instructions to follow.
Kind Regards
Posted: 12 Jan 2021, 21:49
by technet2
detailed steps:
1. KINGOROOT (I did it. Is it necessary?
download:
https://www.kingoapp.com/android-root/download.htm
setup option:
Root Android 4.2.2(Jelly Bean) with KingoRoot (PC Version) - be patient, update 15min or more
https://www.kingoapp.com/root-tutorials ... ot-apk.htm
2. TWRP
download:
https://odindownload.com/download/Odin3_v3.14.1.zip
https://eu.dl.twrp.me/p5110/
setup instruction without point 1 for Windows 10
https://nerdschalk.com/twrp-recovery-fo ... ab-2-10-1/
3. SLIMROM7
download -> both necessary (SLIM7 best is lastest; PIKO is light but can be higher)
SLIM7
https://androidfilehost.com/?w=files&fl ... t_dir=DESC
GAPPS
https://opengapps.org/ (HOME->ARM->7.1->PIKO)
setup instruction (first wipe 4.2.2, then installation SLIM7+GAPPS,PIKO)
https://www.youtube.com/watch?v=wb2xdhvcUoQ
4. RESTART
be patient, the first startup takes about 5-15 minutes
With these steps I have a useful device for qDslrDashboard
But of course, everyone does it at their own risk...
Good luck!
Posted: 15 Jan 2021, 09:28
by LordLiverpool
@technet2
Thank you very much, I really appreciate your time and help.
I will definitely try this out on my P5110 as I'm really keen to use qDslrDashboard.
Thanks again!
