Lrtimelapse issue with Canon R6 using the 2 SD cards ?
djoubert
Post by djoubert »
With my Canon R6, I set jpeg on the SD 1 and Raw on the SD 2. my issue is that time to time ( not always??? I have the following message : ""Can't enter LRTumelapse screen / Image format is not Raw+Jpeg or Jpeg". / If I set the both Jpeg and Raw on the SD1, it seems to always work...
Thank you to have a look
