Hello!
The Live View Zoom buttons are without any effect using qdslrdashbard v3.6.4 with my new Nikon Zfc. With my other Nikon (Z50) it works fine.
The only workaround is setting it to "camera mode" instead of "host mode" and use the zoom buttons at the camera itself. But after taking a capture, this will be reset to standard (no zoom) and so the liveview zoom is lost again.
So can you please fix this problem and activate the zoom buttons in the qdslrdashbard software? Thank you!
Regards, Volker
No Live View Zoom with Nikon Zfc
Re: No Live View Zoom with Nikon Zfc
Can you check the USB product ID for the Zfc. Eventually contact me with the support email.
How can I check this?
btw, with usb cable it's working fine
After you connect with USB check the log screen in qDslrDashboard, it should print out.
You could also check in Windows device manager after you connect your camera with USB to your PC
it doesn't show any
RoadRailer
Per the Zadig utility, the USB information is as follows:
If connected to the Z fc via WiFi, the live view button is available but does not activate a live view when clicked.
libwdi:debug [wdi_create_list] Device description: 'USB Input Device (Interface 1)'
libwdi:debug [wdi_create_list] Hardware ID: USB\VID_04B0&PID_044F&REV_0120
libwdi:debug [wdi_create_list] Compatible ID: USB\Class_06&SubClass_01&Prot_01
libwdi:debug [wdi_create_list] Driver version: 10.0.19041.746
libwdi:debug [wdi_create_list] WUDFWpdMtp USB device (23): USB\VID_04B0&PID_044F\0000003007314
libwdi:debug [wdi_create_list] Device description: 'NIKON DSC Z fc'
Hello!
Just wondering if the Nikon Zfc works with QdslrDashboard since I'm looking to buy a new one.
I'm using QdslrDashboard with Nikon d5500 and d7200, it works well so I'm looking to any users that is already using Nikon Zfc with QdslrDashboard.
Thank you!
Thank you!
I added the ID or the Zfc so it should work.
Nikon Zfc driver change usb by cable connection
Hello everybody,
I connected my new Nikon Z fc to my PC via usb cable. Nikon Webcam Utility and Nikon Transfer, Zoom and also ODB recognized the Camera. Qdslrdashboard didn't. So I changeged the Usb-Driver with Zadig as described on the homepage https://dslrdashboard.info/windows-inst ... sb-driver/. After changing, qDslrDashboard worked fine! But all the other Programms above mentioned, didn't work any more. Found no solution for that. Reinstalling, changing driver, resetting Camera etc. etc. did not help.
What can I do? Please Help!
