DDserver not found, Android, TP-LINK MR-10U
Posted: 16 Apr 2022, 11:14
by FnW08
Hi, Hubaiz,
Understand this is like a obsolete question as similar threads have been quite for years. I wouldn't be raising this questions hadn't I happened to find a forgotten MR-10U.
System info:
Hostname LEDE
Model TP-Link TL-MR10U v1
Firmware Version LEDE Reboot 17.01.5 r3919-38e704be71 / LuCI lede-17.01 branch (git-18.180.55366-b78664c)
Kernel Version 4.4.140
Installed 2.0-13 version of DDserver on upgraded TP-LINK MR-10U(expanded Rom to 16M and Ram to 64M).
DDserver seen on the page: Systems > Software with the suffix 2.0-13, can also be seen on the page: Systems > Start up with buttons showing Enabled.
Tried Canon 550D and 50DIII with 3 different USB cables connecting them to the router. My PC can control the 2 cameras to take photos via each one of the cables.
Android 3.6.3 version works fine with both cameras when using the same USB cables connecting them with my Android phone.
When JI use the MR-10U trying wireless control, after touching the upper-left corner 3-to-1 hub icon, the app indicates: "searching for DDServer,", then "DDServer not found, connecting to IP 192.168.1.1", then "List connected DSLR at IP: 192.168.1.1", no camera models showed then.
When connecting Canon D550 to the router, the back screen of the camera shows "busy", same as it's connected to a PC.
Plug a USB flash drive on the USB port of the router, it works with the router and the right storage capacity could be showed by using usbutils and WinCP.
Parts of the log here:
Sat Apr 16 18:58:29 2022 kern.info kernel: [ 5784.273104] usb 1-1: new high-speed USB device number 63 using ehci-platform
Sat Apr 16 18:58:29 2022 kern.err kernel: [ 5784.703095] usb 1-1: device descriptor read/64, error -71
Sat Apr 16 18:58:30 2022 kern.err kernel: [ 5785.803208] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
Sat Apr 16 18:58:30 2022 kern.info kernel: [ 5785.923088] usb 1-1: new high-speed USB device number 64 using ehci-platform
Sat Apr 16 18:58:31 2022 kern.err kernel: [ 5786.563069] usb 1-1: device descriptor read/64, error -71
Sat Apr 16 18:58:32 2022 kern.err kernel: [ 5787.273056] usb 1-1: device not accepting address 64, error -71
Sat Apr 16 18:58:32 2022 kern.info kernel: [ 5787.277652] usb usb1-port1: attempt power cycle
Sat Apr 16 18:58:32 2022 daemon.info odhcpd[738]: Using a RA lifetime of 0 seconds on br-lan
Sat Apr 16 18:58:32 2022 kern.info kernel: [ 5787.923103] usb 1-1: new high-speed USB device number 65 using ehci-platform
Sat Apr 16 18:58:33 2022 kern.err kernel: [ 5788.050144] usb 1-1: device descriptor read/8, error -71
Sat Apr 16 18:58:33 2022 kern.err kernel: [ 5788.279138] usb 1-1: device descriptor read/8, error -71
Sat Apr 16 18:58:33 2022 kern.info kernel: [ 5788.723086] usb 1-1: new high-speed USB device number 66 using ehci-platform
Sat Apr 16 18:58:34 2022 kern.err kernel: [ 5789.203032] usb 1-1: device not accepting address 66, error -71
Sat Apr 16 18:58:34 2022 kern.err kernel: [ 5789.207609] usb usb1-port1: unable to enumerate USB device
Sat Apr 16 18:58:34 2022 kern.info kernel: [ 5789.493305] usb 1-1: new high-speed USB device number 67 using ehci-platform
Sat Apr 16 18:58:34 2022 kern.err kernel: [ 5789.739137] usb 1-1: device descriptor read/all, error -71
Sat Apr 16 18:58:35 2022 kern.info kernel: [ 5790.493086] usb 1-1: new high-speed USB device number 68 using ehci-platform
Sat Apr 16 18:58:36 2022 kern.err kernel: [ 5791.093285] usb 1-1: device not accepting address 68, error -71
Sat Apr 16 18:58:36 2022 kern.info kernel: [ 5791.098189] usb usb1-port1: attempt power cycle
Sat Apr 16 18:58:37 2022 kern.err kernel: [ 5792.313072] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
Sat Apr 16 18:58:37 2022 kern.info kernel: [ 5792.433006] usb 1-1: new high-speed USB device number 70 using ehci-platform
Sat Apr 16 18:58:37 2022 kern.err kernel: [ 5792.912984] usb 1-1: device not accepting address 70, error -71
Sat Apr 16 18:58:37 2022 kern.err kernel: [ 5792.917564] usb usb1-port1: unable to enumerate USB device
Sat Apr 16 18:58:38 2022 kern.info kernel: [ 5793.203093] usb 1-1: new high-speed USB device number 71 using ehci-platform
Sat Apr 16 18:58:38 2022 kern.info kernel: [ 5793.445084] usb 1-1: USB disconnect, device number 71
Sat Apr 16 18:58:38 2022 kern.info kernel: [ 5793.723090] usb 1-1: new high-speed USB device number 72 using ehci-platform
I would appreciate if you could help me work out a solution to crack this problem.
Thanks!
Re: DDserver not found, Android, TP-LINK MR-10U
Posted: 23 Apr 2022, 07:18
Not sure I understand what is the problem?
Is it not working with the latest qDslrDashboard version?
Posted: 24 Apr 2022, 11:10
by FnW08
Hi, Hubaiz,
Thanks for chime in on my question, appreciated.
The app (version 3.6.3) work fine if I connect my android phone direct with my Canon 550D or 5DIII via the USB cable.
But if I connect the cameras via the same cable to a upgraded TP-LINK MR-10U(expanded Rom to 16M and Ram to 64M), and my android phone is WIFI-connected to this AP-setup MR-10U, the app indicates that DDserver not found on 192.168.1.1, and no camera showed on the list of connected DSLR.
here is the log of today's connection for you information:
Sun Apr 24 10:55:28 2022 daemon.info dnsmasq[1440]: read /etc/hosts - 4 addresses
Sun Apr 24 10:55:28 2022 daemon.info dnsmasq[1440]: read /tmp/hosts/odhcpd - 0 addresses
Sun Apr 24 10:55:28 2022 daemon.info dnsmasq[1440]: read /tmp/hosts/dhcp.cfg02411c - 2 addresses
Sun Apr 24 10:55:28 2022 daemon.info dnsmasq-dhcp[1440]: read /etc/ethers - 0 addresses
Sun Apr 24 10:56:48 2022 kern.info kernel: [ 346.153704] usb 1-1: new high-speed USB device number 2 using ehci-platform
Sun Apr 24 10:57:18 2022 kern.info kernel: [ 377.046754] usb 1-1: USB disconnect, device number 2
Sun Apr 24 10:58:29 2022 kern.info kernel: [ 447.692850] usb 1-1: new high-speed USB device number 3 using ehci-platform
Sun Apr 24 11:00:22 2022 kern.info kernel: [ 560.053489] usb 1-1: USB disconnect, device number 3
Sun Apr 24 11:00:23 2022 kern.info kernel: [ 561.161779] usb 1-1: new high-speed USB device number 4 using ehci-platform
The upgraded TP-LINK MR-10U works fine are a router, I am replying this post at my PC that is connected to Internet via it.
Should I upgraded to the latest version? Or there are other ways to fix it?
Many thanks!
Frank
Posted: 30 May 2022, 08:08
by alisawhalen
Did you get the latest version?
Posted: 13 Jun 2022, 12:07
by FnW08
Hi, alisawhalen,
I downloaded both ddserver_0.2-4_ar71xx and ddserver_0.2-13_ar71xx version and tried both, none worked, not aware if there is any newer version out there.
Would be appreciate if any one could help me solve the problem.
Many thanks!
Posted: 04 Apr 2024, 17:10
by FnW08
Just revisiting this problem to see if any updates, seems may dependencies have been elimiated for the old TP-Link 10U, the latest openwrt version is LEDE 17 or Chaos 15, when typing in opkg update, no files could be found, when typing in opkg install /tmp/ddserver_0.2-13_ar71xx.ipk, not libusb and another lib could be located.
