Controlling multiple nikonZ cameras at once
Posted: 03 Jun 2023, 08:37
Hi
Usually i contact Zoltan directly but trought the forum maybe someone else can benefit of it. I recently had to make a video from 3 different viewing angles and i used my Z6 Z7 and Z7II. The cameras were like 15m distant from each other and i also had to climb a bit to reach them given to their position. Also the recording limit of 30min means that if i have to record longer i will have to reach every camera to restart recording.
I now already ordered a TP-Link3020 to create a ddserver. But if i understand that correctly the multiple cameras then have to be connected by USB to the Router over an USB Hub.
Now my question is: is there a possibility to control 3 Cameras connected to a wifi-Network? I tried to connect my Z6 to my Router at home but was not able to reach the camera with qdslrdashboard. Maybe i did something wrong but it is also an other kind of wifi as connecting the camera directly to the smartphone.
any suggestions?
best regards
Lucio
any suggestions?
best regards
Lucio
