RAW on Sony A6000
Posted: 03 Mar 2015, 12:22
by McUles
When i setup RAW+JPEG in my Camera und make Fotos with qDSLRDashboard, i just have JPEG on my SD Card.
Wha do i weonga.
Re: RAW on Sony A6000
Posted: 03 Mar 2015, 12:59
There is no command in the Sony API to get the RAW picture, only to get a preview picture after capture.
Posted: 03 Mar 2015, 15:46
by McUles
Hi hubaiz,
i don't nervt the raw in my Tablet but on my cameras SD Card.
On the sd is just a jpeg saved. Thats my trouble.
Posted: 03 Mar 2015, 19:15
Will check, but there is only a command to start the capture and the camera will do it according the current settings.
Posted: 03 Mar 2015, 20:33
by McUles
Hi again :)
I found a second Setting for the quality in the A6000.
When the remote app in the camera is started and qDD started, you can setup the RAW specially for the remote app.
That did the trick.
Thanks for your support!
Posted: 02 Jan 2019, 10:01
by Headlessbody
McUles wrote: ↑03 Mar 2015, 20:33 Hi again :)
That did the trick.
Found this old post... Where is this setting? i can't find it....
Posted: 02 Jan 2019, 16:46
After you connect your controlling device wireless to the camera wireless on your camera press the 'Menu' button this will open the 'Smart remote controll' application settings and there your can set the capture image format.
