Canon 7D and Canon 5D Mark III
Posted: 10 Jul 2015, 14:40
				Hi.
I tested on Canon 7D and Canon 5D Mark III, via USB and WiFi using TP Link router MR3040. Application is installed on HTC One, and Samsung Galaxy Tab 10,5. On both device I have Android 5.0.2.
I make timelapse using sunset mode, max ISO set to 3200, and max shutter speed set to 4 sek.
This is my test results:
1. On Canon 7D application via USB or Tp Link application crashes and closed when try to connect to camera. This is happened both on HTC One and Samsung Galaxy tab 10,5.
2. On Canon 5D Mark III application on Tablet and HTC One connected successfully. But always in LRTimelapse mode application stop changing shutter speed when is equal 1 sek. and never change ISO. The picture at the end is dark and references values is less than 12.
Maybe I something wrong.
Thank you in advance for your help.
