No picture stored in camera memory
AInglese
Post by AInglese »
Hi.
With V0.3 Beta 8 for Android ARM, when I press the 'Capture button' (color of the button: white) the camera, a Canon EOS 5D Mark II, makes a sound as if a picture is taken but there is nothing stored into its CompactFlash memory.
If I first long press the 'Capture button' it becomes red and further presses result in pictures taken and transferred to the folder of the tablet wich is defined by the general settings. This behavior is correct.
No such problem with V0.2.9.
Re: No picture stored in camera memory
Here is a debug build: https://drive.google.com/file/d/0BxMZ8X ... sp=sharing
It will create a qdd_<date_time>.log file in your Android device Documents folder. Please send it to the support email.
Is maybe mirror up capture enabled?
Was live view enabled?
AInglese
Post by AInglese »
Thank you for the debug build. I will try it tomorrow morning and email the log file.
No special setting for the mirror (or it was beyond my will).
Yes live view was enabled. By the way I noticed that live view turns into black and white while capturing and then turns back to a colored view when done.
