Option to view Dual ISO Images
Posted: 31 Jul 2015, 11:24
Hi, I assume that most readers no about the app MagicLantern
http://www.magiclantern.fm/
Anyway they have made it possible to take an image with Dual ISO. The sensor takes in the image at two seperate exposures. 200 ISO and 800 ISO for example in the one image and this gives a much greater dynamic range within an image and in many cases does away with the necessity to use HDR on many occassions but to view the images on a computer you need something like Lightroom and the plug-in that is offered free by the developers of MagicLantern.
http://www.magiclantern.fm/forum/index. ... #msg107262
I have got the images to transfer with QDSLRController from camera to Nexus 7 to be able to view them at a larger screen size however they have banding across them as you would get if you tried to view on a computer without the MagicLantern plug-in so!!!
Is there any way to use the code from the MagicLantern plug-in free app to allow images to be viewed without the banding on a tablet?
Sorry about the story but had to try and explain best I could.
Russ
Russ
