Nikon high speed transfer fails with USB connection
Posted: 05 Oct 2015, 19:10
Setup:
V0.3 beta9
Nikon D7200, USB 2.0 connection directly to the computer (no hub)
OS X 10.7.5
Hello there,
Thanks for the new beta! Things are a lot more reliable now.
Here's a problem I encountered but have a workaround:
With the D7200 connected via USB cable, after taking a shot, the image viewer will come up but displays nothing, just black. Same with trying to view another image from the camera within the same viewer. But if I turn off "Use Nikon high speed transfer" from the qDD settings the viewer loads the image correctly.
LiveView seems unaffected.
No problem with high speed transfer enabled and a WiFi connection to the same camera.
What do you think?
V0.3 beta9
OS X 10.7.5
Hello there,
What do you think?
