iOS - qDslrDashboard is crashing on iPad and iPhone
Re: iOS - qDslrDashboard is crashing on iPad and iPhone
By "factory image" I meant OpenWRT image described as "factory" not TP-Link's original FW.
Here are download links (near bottom of page): http://dslrdashboard.info/downloads/
Flash both images.
I also for the first time flashed different OpenWRT release as first image and could not connect with camera at all.
valid_like_salad
Post by valid_like_salad »
GonzoG wrote:By "factory image" I meant OpenWRT image described as "factory" not TP-Link's original FW.
Flash both images.
Reflashed with both images (in the correct order) and I'm able to connect still, but only for a few seconds before I lose connection. Same issue as before, didn't seem to improve or deteriorate.
So there are only 2 possibilities left:
- bad cable connection ( cable or ports in camera/router) - check if USB LED stil lights up when connection was lost.
- bad router
MR3040 is very demanding when it comes to USB connection. I had problems with few cables that worked correctly connected to PC but mr3040 was losing connection to camera.
valid_like_salad
No luck with new cables. Router was brand new. Lights all stay illuminated.
valid_like_salad
I'm using the USB cable supplied with a GoPro, is there any recommended cable to use with the TP MR3040? I've tested many with the same failed results.
Only that it is USB 2.0 cable.
Woolf
Post by Woolf »
I am not able to delete the pics i have shot from My iphone. Cam is nikon d750
