LRTimelapse - sometimes "Capture sample" doesn't work
Posted: 12 Mar 2015, 10:58
by Didi
Sometimes when I have started LRTimelapse and I'm pressing the capture sample button (display next JPG is active) the picture will taken but not transfered to the tablet. So I can't start the "auto holy grail". (canon 70d -wifi - asus android 4.4.2) Whats wrong with my settings, maybe?
Re: LRTimelapse - sometimes "Capture sample" doesn't work
Posted: 16 Mar 2015, 20:50
Did you maybe find some pattern regarding this.
I was trying to reproduce this with the 650D but couldn't.
Posted: 11 Apr 2015, 14:52
by Didi
I think this is a wifi problem. I found out, when I make a wifi connection the first time with the canon 70d ... so the LRTimelapes doesn't work full. The "capture sample" button works, but the picture will not transfered to the tablet.
BUT:
When I disconnect wifi and connect wifi again then it works fine and I can use the auto holy grail.
My solution: I have to connect the wifi 2 times.
Posted: 11 Apr 2015, 17:57
You can try this debug build:
It will create a qdd_<date_time>.log file in your Documents folder for each start.
So try to connect to 70D and enter LRTimelapse and press the 'Capture sample' button.
If it does not work then reconnect as you described and try again to press the 'Capture sample' button.
Please send the log file to the support email.
This is the same build without the debug messages:
Posted: 12 Apr 2015, 13:43
by Didi
I have tried, but the problem is still the same. I have sent the logfiles to the support email.
Posted: 28 Apr 2015, 19:21
by fanne
I have the same behavior on my 70d with a Lenovo tablet. Connecting twice and the second time the capture works.
Cheers,
fanne
