More compact parameters (apert., shutter)
Posted: 14 Mar 2015, 10:21
Setting values for aperture and shutter speed could be a bit easier if there was a kind of matrix of values instead of a very long list of lines to scroll. In case there were too many values to choose from (like shutter speed with long time exposures) it could be split into one matrix with more common values (like 1/8.000 sec ... 1 sec) and one matrix with longer time settings.
Another wish:
Sometimes I get lost (camera properties display) within all of these fields. They are listed by labelled lines but the fields within one line sometimes can hardly be recognized and distinguished. E.g. one doesn't know immediately the meaning of a field plainly named "52.0" or "Off" as long as one hasn't clicked onto that field which is unfavourable and time-consuming. So, maybe with additional small labels or more customized icons it could be easier to navigate.
Because it is the most excellent feature of qDD that it is capable of accessing and setting almost everything on your camera!
Another wish:
