Live View On Camera LCD Screen on D7000
Easy Mark
Post by Easy Mark »
This seems to be an issue with the TP Wireless router (instead of with qDSLRDashboard).
Is there a way to use live view on the CAMERA LCD panel after plugging in and turning on the router?
Whenever the router is plugged in, I can't switch back to using the LCD on the back of the camera for live view (even if I don't have qDSLRDashboard running). I have to turn the power on the router off.
anyone know if there is some setting in Nikon Menu that will allow me to view in the camera LCD screen once the router is plugged in and turned on?
Thanks in advance.
Re: Live View On Camera LCD Screen on D7000
It.is not the issue with router nor qDD. It is how Nikon works.
When you connect camera with USB you cannot use camera LCD for LV. Only remote app can be used.
Easy Mark
Post by Easy Mark »
Thank You for the reply!!!
