Hi there,
first of all - many thanks for programing the app it's a great tool.
However I helped a friend to set up his D850 as I had done before for mine.
Both using our ipads for control. Interestingly I'm unable to use exposure times above 1/30 while he can.
I have reinsalled the app - but still no luck.
Any idea where to look or what to change?
Thanks Berthold
qdslr diffenent option using similar equipment D850 Ipad
Berthold1959
Re: qdslr diffenent option using similar equipment D850 Ipad
Was the camera maybe in live view movie mode?
Berthold1959
no none of them was.
we have redone the procedure multiple times without any luck. Even reinstalling the app on the Ipad didn't get me the long-exposure options
Can you reproduce this? If yes then a screenshot with the camera settings screen would help.
Berthold1959
Hope these are the once you are asking for - and they can help solving the issue
Many thanks Berthold
- IMG_2826.JPG (109.31 KiB) Viewed 19244 times
- IMG_2825.JPG (123.76 KiB) Viewed 19244 times
- IMG_2824.JPG (83.04 KiB) Viewed 19244 times
Berthold1959
ups, one more screen
if you need specific ones, please let me know
- IMG_2827.JPG (105.22 KiB) Viewed 19244 times
While the live view is not activated and still connected to the camera try and change the shutter speed on the camera.
Can you go below 1/30 on camera?
I couldn't reproduce it on D7100, D500 and Z6. I only get this when I activate movie live view.
Did you both try with the same D850? I mean your friends iPad with the D850 works good and then your iPad with the same D850 is not allowing shutter speed under 1/30?
Or did you try with friends iPad and friends D850 and then with your iPad and with your D850?
Berthold1959
Will try the other settings when I meet up with my friend next time.
Thanks for your great support.
live view movie mode vs live view photo mode perhaps...
