Problem connecting Nikon D7100 over TL-MR3020
mosim
Post by mosim »
I´d like to connect a Nikon D7100 with a TL-MR3020 router to my computer and qdslrdashboard.
First of all I connected the Nikon to my computer over USB and it did not work. So I had to install the USB driver (http://dslrdashboard.info/windows-insta ... sb-driver/) to get it work, but then perfectly.
But I need this wireless...
1) I flashed the firmware of the MR3020 with the software I found here: https://wiki.openwrt.org/toh/tp-link/tl-mr3020 (Install and Upgrade)
2) Then I did the Wifi settings and could connect my computer to the MR3020.
3) I connected the Nikon with the USB cable to the 3G/4G port (is this ok ?)
4) I opened qdslrdashboard and did a long klick on the Network symbol, I changed the IP Adress to the IP adress of the MR3020 and said OK.
Nothing happened...
My search in some forums began,
I changed the firewall settings of the MR3020 - nothing happened
I changed the computer - nothing happened
I did something I found in the internet like "first switch on router an then switch on camera" or the other way around- nothing happened
What I´m not able to dois this: http://dslrdashboard.info/ddserver-package-updater/
I think because there is not ddserver entry in the MR3020 (I got an error like this "cannot remove ddserver,ddserver not found")
I hope there is anyone who can help me or is there a detailed description step by step how it workes?
Do I have to change something in the NIKON menu?
Thanks, Markus
Re: Problem connecting Nikon D7100 over TL-MR3020
You have the OpenWrt with ddserver for MR3020 here:
factory: https://drive.google.com/file/d/0BxMZ8X ... sp=sharing
sysupgrade: https://drive.google.com/file/d/0BxMZ8X ... sp=sharing
As you already have OpenWrt on it you can use the sysupgrade image and the instructions here: http://dslrdashboard.info/tp-link-mr304 ... e-upgrade/
mosim
Post by mosim »
Works perfect
thanx
