qdslrdashboard v.3.5.3_winx86 crashes directly after connecting
meise86
Post by meise86 »
I have a Nikon D5100 connected to a TP-Link ML-3020. Openwrt seems to work fine (Camera detected in Syslog).
I try to connect to the ddserver with a windows 7 x86 Laptop running qdslrdashboard v.3.5.3. When I hit the "network button", the connection info says:
Searching for DDServer
DDServer not found, connecting to IP 192.168.1.1
List connected DSLR at 192.168.1.1
Found 1 DSLR at IP 1.92.168.1.1
Connecting to DDServer DSLR NIKON NIKON DSC D5100
after this, qdslrdashboard does no longer response and windows asks to close the program.
I do not know where to start since there is no error message. Are there any suggestions how to find (and fix) the problem?
Greetings
Meise
Re: qdslrdashboard v.3.5.3_winx86 crashes directly after connecting
How do you connect your laptop to the MR3020 (wireless or network cable) ?
Is your laptop only connected to the MR3020 or also it is connected to your home network?
