On my Raspberry 3, I have installed Raspbian Stretch and downloaded V.3.5.5. FOR RASPBIAN STRETCH. When I double-click on "qDslrDashboard" or "qDslrDashboard.sh", a window "Execute File" appears, but when I then press "Execute", nothing happens. How can I properly install and start qDslrDashboard?
Install qDrslDashboard on Raspbian Stretch
Re: Install qDrslDashboard on Raspbian Stretch
Start with ./qDslrDashboard.sh
Check that all the required libraries are installed.
Thanks for your answer, but when I run './qDslrDashboard.sh' in the terminal, I get an error permission denied, No such file or directory.
What am I doing wrong?
Has anyone been able to install qDslrDashboard 3.5.5 on a Raspberry 3 (Raspbian Stretch), or doesn't that work?
@hubaiz: what do you mean with
What libraries should be installed? I'd really appreciate your help!Check that all the required libraries are installed.
After installing the dependencies, when running the qDslrDashboard script. I have the following message:
JIT is disabled for QML. Property bindings and animations will be very slow. Visit https://wiki.qt.io/V4 to learn about possible solutions for your platform.
QQmlApplicationEngine failed to load component
qrc: /qml/qml/main.qml: -1 File not found
Can you help me ?
Can you help me ?
- Capture raspberry.JPG (38 KiB) Viewed 9449 times
Please check this post: viewtopic.php?f=6&t=2468
@hubaiz: thank you for your answer. I've done all steps mentioned in your suggested post. However, the program does not start, I get the following output in the terminal. I'm connected via VNC to my Raspberry 3 since I don't have a monitor. Any idea what causes this issue?
- Screen Shot 2018-02-22 at 16.26.47.jpg (85.77 KiB) Viewed 9430 times
It will not work with VNC as it can't transmit OpenGL as far I know.
@hubaiz: thank you. My idea was that I can connect the Raspberry via USB to my Nikon camera and then trigger a time lapse. Since I don't have a dedicated monitor for my Raspberry, I create a personal hotspot from my Macbook / iPhone and did all the installation. This is much more convenient since I don't need another monitor and keyboard and don't have to carry this additional gear when I'm travelling. Hence, I thought that I can steer dslrdashboard via VNC from my iPhone.
Any other solution how to run dslrdashboard on a Raspberry 3 without a monitor? Thanks.
