Autofocus Nikon Z6
damanvines
Autofocus Nikon Z6
Post by damanvines »
The auto focus feature in the app doesn’t seem to be working with the Z6 camera. I can tap on the screen and see the yellow box move but it will not focus the camera, even when I tap the AF button. I’ve checked and the camera is in auto focus mode AF-S, autofocus works fine when not connected to the app
Re: Autofocus Nikon Z6
If you 'tap' the live view screen it will only changes the area where the focus will be performed. To perform the focusing you must press the 'AF' button on the left side.
In qDslrDashboard settings you can enable the 'AF after focus point change' option, with it enabled after you change the focus area qDslrDashboard will automatically start the camera autofocus.
