No Live View Zoom with Nikon Zfc
Posted: 28 Oct 2021, 10:39
by volkerw
Hello!
The Live View Zoom buttons are without any effect using qdslrdashbard v3.6.4 with my new Nikon Zfc. With my other Nikon (Z50) it works fine.
The only workaround is setting it to "camera mode" instead of "host mode" and use the zoom buttons at the camera itself. But after taking a capture, this will be reset to standard (no zoom) and so the liveview zoom is lost again.
So can you please fix this problem and activate the zoom buttons in the qdslrdashbard software? Thank you!
Regards, Volker
Re: No Live View Zoom with Nikon Zfc
Posted: 06 Nov 2021, 08:15
Can you check the USB product ID for the Zfc. Eventually contact me with the support email.
Posted: 09 Nov 2021, 10:35
by volkerw
How can I check this?
Posted: 11 Nov 2021, 10:46
by volkerw
btw, with usb cable it's working fine
Posted: 13 Nov 2021, 09:30
After you connect with USB check the log screen in qDslrDashboard, it should print out.
You could also check in Windows device manager after you connect your camera with USB to your PC
Posted: 21 Dec 2021, 10:10
by volkerw
it doesn't show any
Posted: 20 Aug 2022, 22:14
by RoadRailer
Per the
Zadig utility, the USB information is as follows:
libwdi:debug [wdi_create_list] Device description: 'USB Input Device (Interface 1)'
libwdi:debug [wdi_create_list] Hardware ID: USB\VID_04B0&PID_044F&REV_0120
libwdi:debug [wdi_create_list] Compatible ID: USB\Class_06&SubClass_01&Prot_01
libwdi:debug [wdi_create_list] Driver version: 10.0.19041.746
libwdi:debug [wdi_create_list] WUDFWpdMtp USB device (23): USB\VID_04B0&PID_044F\0000003007314
libwdi:debug [wdi_create_list] Device description: 'NIKON DSC Z fc'
If connected to the Z fc via WiFi, the live view button is available but does not activate a live view when clicked.
Posted: 24 Oct 2022, 10:58
by Teditedi
Hello!
Just wondering if the Nikon Zfc works with QdslrDashboard since I'm looking to buy a new one.
I'm using QdslrDashboard with Nikon d5500 and d7200, it works well so I'm looking to any users that is already using Nikon Zfc with QdslrDashboard.
Thank you!
Posted: 07 Nov 2022, 08:02
I added the ID or the Zfc so it should work.
