Page 1 of 3
how to install ddserver on a 3020 tplink router ?
Posted: 15 Mar 2015, 17:33
by djoubert
I saw that ddserver should run also an a 3020 TPlink router.
I install Openwrt on the 3020 router,
then I tried to use the ddserver package updater to install ddserver,
I didn't succeed.
I am wondering if it's the right batch, because it seems that the batch starts to remove existing ddserver
so any idea about how to install a ddserver on a 3020 tplink router
Thank you for any help
Dominique
Re: how to install ddserver on a 3020 tplink router ?
Posted: 16 Mar 2015, 11:12
by djoubert
I am still trying...
I copied with winscp tje ipk file to the /tmp directory.
Then I launch the opkg install command with the ipk file
unfortunately I got an error : "/var/lock/opkg.lock No such file or directory.
It seems that it is a known bug within openwrt? , how to have a workaround ?
any other idea ?
Dominique
Posted: 16 Mar 2015, 11:56
Sorry, seams I missed your post.
I already have OpenWrt for MR3020 here with ddserver included:
factory:
sysupgrade:
Posted: 16 Mar 2015, 15:41
by djoubert
Thank you very much, I succeeded to have my 3020 running.
I am able to have DSLRdashboard discovering and managing DSLR connected with USB
The next step where I dont succeed so far is to discover DSLR with the 3020 connected to my first 3040.
( the goal being to have one dslr connected on each one of the both routers.
so on each one separatly, it's OK
I configured the 3020 following the procedure you provided here :
when I long pressed the network button for 192.168.3.1 as IP I am not able to discovered the dslr
When I connect this dslr to the 3040 I discovered it with long press to 192.168.1.1
using the network disagnostic feature, I am able to ping each one from each other.
Any Idea about what is wrong in my configuration ?
I also tride to change to 192.168.2.1 the 3040 / same results.
I use DSLRdashboard 2.04, but I tride with 2.06 / same results
Thank you very much
Dominique
Posted: 16 Mar 2015, 15:56
Probably you are missing some step from the instructions for multiple routers.
Did you add the manual route to the AP device?
Posted: 16 Mar 2015, 17:03
by djoubert
Yes, probably I missed something...
I tried to check many times
Yes I add the static route as described page 10 of your detailled instruction.
may I attached some screenshots ?
Posted: 16 Mar 2015, 17:30
by djoubert
Here are the screenshots of the both configurations
Thank you to have a look
maybe it's not normal to have a question mark for the 3020 associated station IP ( first screenshot )
Best regards
Dominique
Posted: 16 Mar 2015, 17:31
by djoubert
Also the 3020 screenshots about interfaces
Posted: 16 Mar 2015, 17:35
by djoubert
last screenshots about the 3020 ( firewall and Wifi )
Thank you very much
Dominique
Posted: 16 Mar 2015, 20:29
When you connect your PC wireless with the AP wireless
- can you access the
http://192.168.2.1 from your web browser
http://192.168.3.1 from your web browser
in qDD if you long press the 'Network' button and enter 192.168.3.1 and then connect can you access the connected camera?
