On Canon D1100, when starting live recording, suddenly the display squeezes it´s high to half (see attached fotos). No Problem with Nikon 5200, but I have no clue, why this happens when the Canon D1100 is connected.
Is that a knwon problem, or is there something specific to switch in qDslrDashboard or on the Camera?
I tried everything, but still the same, only on Canon D1100, the squeezed half-high LiveView-Display.
Any Idea what the problem could be? Does anyone knows this behavior?
Greetings, Gunneg
(Frankfurt/M., Germay)
sudden half-size display in liveView Recording, Canon D1100
- LiveView recording.JPG (208.45 KiB) Viewed 6785 times
Re: sudden half-size display in liveView Recording, Canon D1100
The live view image is sized according the information that qDD gets from the camera.
You see me confused.
I still don´t know, what to do, to solve the problem.
Why is the Screen "squeezed" just and only while recording a video?
Not when taking pictures, not when viewing without recording.
While recording, only the y-axis is sqeezed to half-size, while the x-axis remains unchained.
This is only happening on the computer-screen, while the recorded video is always normal size.
Have you ever seen this happen?
Do you think, there ist something to adjust on the Camera?
I tried every Menü-Item in the Camera, but there ist nothing about "sqeezing" as a function oder filter,
nor a ratio-number to enter, to set this effect.
As for now, while recording, it seems like something is broken (hardware) oder misstuned (parameter-setting).
Please, if anybody has seen this behavior or has an idea, of what setting might do the trick or solve it,
you would do me a great favor.
Gunneg
Gunneg
